Why can't it be used.Obviously the proper CW1308 twisted pair solid cable can't be used for alarms,
What parameter of telephone cable prevents it being used as alarm cable. ?
Solid-core cable, the same as used for telephone wiring, is used extensively in North America without any big problems. For the screw terminals typically found on door contacts and similar accessories (i.e. conductor wrapped around under screw head) it's much better than stranded.
Go on then, tell us why?
How is it any harder than working out what is what with any other type of cabling? In either case you need to check to see which color wire has been used for each function.I came across an alarm the other day that was fully wired with telephone wire, what a joke that was to work out what was what.
Aside from the method Bernard outlined, there are cable testers readily available these days which inject various signals at one end of the cable and then use a receiver at the other end to automatically indicate which conductor is which.How would you know which core was which at each end?
For the reason Bernard has already mentioned - Solid provides a much better connection with a wrap-around screw terminal.
