To the OP, yes of course you can use solid core phone cable to extend your system, you will encounter problems if you overtighten the connection or repeatedly remove and reconnect as it will fracture.
BS4737 allowed the use of soild core cable (lace wiring and tube & baton for example) and these are terminated at a junction box as they are static, 7/0.20mm alarm cable is used from there on (or after a door loop), the standard makes refernace to minimising false alarms, I presume this to be 'a single point of failure' with regard to the wire consisting of 1 conductor, rather that 7strands of 0.20mm.
The 7/0.20 definatly lets you make and remake the same connection a far more number of times than that allowed by single score cable before failure by fatigue.
