many thanks for your help doitall, there are no port valves from the system only 2 stop cocks either side of pump, the hot water to the taps is scolding hot steam as well as water when boiler on full, we can have the programmer or timer set to hot water only or ch and hot water cannot have ch on its own only the water, the boiler is a glow worm majorca radiant convecter fire with back boiler, the cold feed comes up from the bedroom to the ball cock in the header tank new ball cock fitted n water level ok don't know if the boiler has a separate cold feed as only that pipe visible,
the vent comes up from the bedroom into loft and is T,ed of up to the top of the hot water cil and then goes to bend in header tank, there is also another vent from the mid of hot water cil that goes into the cold water storage tank. both cold water feeds to the storage tank and header fill ok when pushing the ball cock down, thanks for taking the time to help it is very much appreceated
