Another possibility is was an old night storage heater point. If so, some work would need to be done at the consumer unit end. But this is assuming you had NS heaters at some time. If you did the outlet would only work at curtain times in a 24 hour period.
Possibly lights. The fireplaces in the house have all been removed blocked up, but these were on the other side of the room/house. I suppose someone could have put a gas fireplace in but this would have made sense on the other wall where the fireplaces were! I suppose if the wires work and it's a 13a I can replace it. It also didn't light up only at night so assume it's not a storage heater switch!
