Inclined to scrap the gas central heating altogether and go with electric rads
I hope you're sitting down when your first Leccy bill arrives!
You have never said how old the boiler is.
Nor have you said why you did not just put the problem back to the installer.
Or just report him to Gas Safe?
This is the problem that professionals have. Installers who advertise very low prices on Gumtree and Ebay and then just do a very cheap and poor quality job!
I suppose he installed it is less than a day?
Tony Glazier
If the case has been drilled, then it needs a new case, end of, anything else would be in contravention of Ideals spec which is not allowed
45 years, i can assure you, if someone at BG wanted to loose there job then yes they could seal it by many other ways in which im very confident it would seal the chamber perfectly, however as it isnt manufacturers spec it would still be I.D. and RIDDOR reportable
BG and others get alot of stick for following rules which COULD actually save some ones life, strange realy
I was thinking Vaillant EcoTec.. but maybe this one is as good/better?
Thats a VERY Cheap price for a power flush and Boiler (even a Main!!)
HOWEVER - what aboput all the leaking fittings you mentioned????
how much to fix that lot!
I think you are being a tad dramatic there, Ollie. If you have a small hole which can be filled nicely with a self tapper, why on earth would it be lethal, and why would you condemn it?
Answer: BG love selling boilers.
Edit: I've tried 4 times to make print smaller, but can't see why it's so big
Boiler is about 5 years old. Installer did the work about 2 years ago and stopped returning my calls after I called him the next morning to say there was a puddle on the floor under the boiler and a smell of gas.. "oh, forgot to tighten the main nut supplying the gas to the boiler.. and check I connected the condensate pipe" Tightened the nut and got transco out who confirmed no gas escaping.
So it seems the boiler was either second hand when installed?
Or it was three years in the box before being installed?
Was it bought off Gumtree as well?
Tony
