I would have asked if you notice this behaviour in warm weather, but presumably you aren't experiencing bitterly cold nights.Yes, and when jump-started, half a mile and it will start on its own and then rest of the day normal driving, it's ok.
I know that's what they do but am trying to understand why.
I can understand that they wear out and get 'weaker', as I called it (after all eight AA batteries are 12V but they won't start a car) but what happens in the first five minutes to make it alright again (temporarily) but leaving it overnight is back to square one (constant drain aside).
Which combustion-engined cars offer them as standard, or even an option, in place of a lead-acid one?yes, we have.
Small, light, lithium batts.
Are you sure he is?.... if a chap were to go out and spend, literally literally, £millions on a brand new car, why would he be stuck with the same 150-year old battery technology as the chap who buys a Dacia?
I would have thought so, too, but I don't think (m)any of the newer technologies that are in widespread use can cope as well with those brief but monstrous loads as can the lead-acid one - and don't forget that (other than the 50mA or 150mA mentioned by EFLI), in contrast with the past the batteries do not have to do anything other than start the engine, so there has perhaps been very little incentive to bring new (and probably expensive) battery technology into cars. Are you old enough to remember the days when long car journey's at night were problematic in some cars, if the dynamo could not keep up with the headlights etc., leaving one was reliant on a progressively discharging battery?I know that lead-acid batteries are good at handling short duration monstrous loads, but even so, have we really not managed to design anything better in the last 158 years?
I'm obviously not sure what you mean by 'several weeks', but 150mA 24/7 equates to about 25 Ah per week - so (in an ideal world) to become totally flat in, say, 8 weeks would be 200 Ah. If you wanted, say, 20% of charge to remain after the 'several weeks' to start the car then (again, in an ideal world), 8 weeks would need a battery of about 250 Ah - so a very hefty battery would presumably be required (particularly in our 'non-ideal' world)?150mA is also not necessarily out of the normal, many newer large cars like Jan XF, Range Rovers, etc can have high quiescent current draws due to the amount of kit fitted – but these vehicles will typically also have big batteries fitted so they will still start after several weeks of non-use.
Quite.I agree with your calculations and I think as you're suggesting a 250 Ah battery would be very large - that's bigger than some HGVs.
As I said, I had no really idea what you meant by "several" weeks - I just guessed at 8 for illustration purposes!A circa 100 Ah battery is more typical for the vehicles I mentioned giving just over 3 weeks' standby allowing ~25% remaining capacity.
Fair enough - that sounds sensible. However, there seem to be very many cars out there which are not that 'smart'!However these vehicles are smart, so as time goes on they will shut down certain systems such as ...
And how long when the battery is, say, 10 years old?A circa 100 Ah battery is more typical for the vehicles I mentioned giving just over 3 weeks' standby allowing ~25% remaining capacity.
