The T&E used to wire up a mobile first aid unit ( DIY "electrician" ) suffered badly from vibration. In places the sheath was worn through to expose the insulation on the conductors.
I'm not designing a rocket. I'm merely trying to source the parts separately to build a much cheaper setup of a readily available kit you can buy on line.
I don't think you realise what is involved in safely wiring a caravan.
I have ensured correct cable thickness, made sure I use dual pole mcb's and I am seeking advice on a diagram I have drawn up, not messing around with electrics to get it right.
It comes with instructions. Something i dont have. Yes....if i paid an extra 50 odd quid i would have them. Just wanted some advice on what i think will be the same as the diagram in the kit.
No, im not wiring a house.
Well we might as well get rid of this section in the forum then.
So to be pedantic once the supply reaches the customer terminals the earth and neutral are split so stricktly speaking the distributor is not connecting his combined N/E to the metal work.
There is nothing to say he must not permit others to do so.
Yes I know the risks having dealt with a lot of neutral faults
I'm a bit confused by that. Under what circumstances would/could a DNO be connecting any of his conductors to (i.e. providing a supply directly to) a caravan or boat ?
If it were a house, you would not be allowed to have that unless the bathroom were so large that the socket could be at least 3 metres from shower or bath. Is there a shower in the 'bathroom' concerned?
Of course I was being 100% serious. I also fully intend on carrying out the installation wearing nothing but Wellington boots as I hear this is the correct way to ensure you are insulated. I might wear a bow tie as well but as of yet I am undecided.
Excuse me. I'm off to play with a toaster in the bath now.
