Now that Trump has left the Paris Accord, your CO detector is going to be going off a whole lot more.
Yes I agree, he is another deluded person who believes Global warming is not real.
Aquaheat, (with respect) it has already been determined that one of the detector was at fault, assuming if it wasn't , and there was real presence of a Co, I took safety action immediately, I turned my boiler off, and opened all doors and windows to ventilate any presence of a possible Co leak.
then 20 or so minutes later, I reset the detector reading stored to zero, and switched it back on, boiler still off, and kept it checked every 10 to 15 minutes to see if it starts to register any reading, it didn't, so after about an hour, I switched my boiler back on, and monitored the reading and it was showing bare minimum and throughout the rest of the day the reading remained low.
I also happened to have a spare detector made by another brand, not kidde, again both have a 3 digit display and both were showing low reading i.e. under 10ppm. The spare one showing just 1ppm, even now it is showing 1ppm.
So later that day I rang my gas safe mate, explained to him how my Co detector went off, he agreed to pop in the next day and check everything for my peace of mind.
Next day, no further alarms activating, still showing low reading, that means it was pointless to knock on a neighbors properties and cause unnecessary drama.
My mate then checked my own boiler and tested various things on it like gas pressure when running on lowest heat and when running on maximum load, and tested the gas analysis, all readings were consistent with that boiler and normal, in fact I remember him saying that for the age of that boiler its Co reading was pretty good and hardly register on his instrument.
he also checked the flue and used a smoke pellet to make sure no gasses penetrated the house, when he was satisfied and the fact that the Co detector did not go off again soon after, it indicates that it was a one off false alarm and possible problem with a co detector.
In other words, my mate followed logical procedure without disturbing my neighbors, not only that their flue faces the garden and well away from my side flue and side door. leading to garden.
What he did under the circumstances was dead right what anyone should do, otherwise it is like saying we have terrorist in our back yard, so the security services should start knocking on everyone's door to find out if anyone is harboring or supporting terrorism, we don't search and stop everyone who walks on two legs! We ( or the authorities) have to sniff them out!
You are now acting very stupid and making a big fool of yourself , I don't intend to entertain idiots like you. |Oh and you can now get stuffed. thanks.So how did he test with a smoke pellet go on amuse us
Oxymoron alert!smartest gas safe engineers .
