The drain pipe idea sounds good, a workmate suggested rather than looking for U shaped pipe of the correct size to get 2 inch pipe and cut a slot 1/2 inch wide along its length then bend the pipe over the insulation and let go, it will spring back and keep it in place, a few cable ties and job sorted.
