No it doesn't work like that, for 6volts its peak voltage would not go anywhere near what is required to trickle charge a 12v battery, normally trickle charge means any charger that limits it maximum peak voltage to 13.8V exact, so once your battery has full charge acquired , its terminal voltage would have reached 13.8v exactly, and therefore if your charger was set to maximum 13.8v then current from charger would automatically reduce since there is now no difference in the voltage between the fully charged battery and the maximum limit of the charger voltage. But yes even if your charger was slightly above 13.8V to say 14v, then full 8 amps may flow, as the charger will try to pump charge into the batteries to pull the battery voltage to 14volts, and the battery would no doubt get pulled to that voltage and cook, as it would now be overcharging. and again as the battery reaches 14volts, it would also be boiling, (gassing ) and so that is no good for battery as it would lose its electrolyte.
as long as your charger limits its maximum voltage to 13.8v and a fully charged battery would then draw only a trickle charge of just a few tens of mili amps like say 50 - 100mA
one way to trickle charge your battery is to lower its output voltage, but this can be difficult since we can never predict mains line voltage as it can vary, consequently with varying mains supply, its output would also vary a bit, so a simple charger without a regulated voltage will tend to go up or down even if you were to use a series resistor to lower the current to trickle amount.
I found that a bench power supply (variable) with variable voltage selector and with two seperate current and voltage meters makes a better charger, you could see what the current is flowing through the battery and what is the charger output voltage and battery voltage with current limiter adjustments too. You can but these for about 30 qyuid.
