In my case the immersion heater could not be used to heat house, as there is no pump on the hot coil it is thermo syphon, so there is no way to get water to circulate.
It would be unusual to do it with the DHW cylinder, but in theory possible though it would need a coil fitted further up than the boiler coil is normally located.
As two selecting radiators so only some rooms heated, not sure how it will work, be it from a immersion heater or main boiler, my previous houses were not well insulated room to room, they were good at stopping heat leaving the house, but it was noted you could turn bedroom radiators completely off, but with down stairs set to 20°C it was hard to get a bedroom below 17°C of course if the room below was not heated then yes bedroom could get very cold.
Very true. As I think I've already (sort of) mentioned, no amount of fancy control is going to get around the laws of physics - but you can minimise the problems. Our house is very sub-optimal, but I'm working on it a bit at a time.
... but where the TRV turns off and boiler is still running what happens to the heat? With modulating boiler OK, but simple off/on it will cycle, is this really better than the old throttling back of the lock shield valve?
Well yes, the eTRVs really need to be linked to the boiler so they can turn it off when heat isn't needed. But I think you misunderstand what the lockshield is for - because it is NOT a "control" valve.
The purpose of the lockshield is to configure the flow rate through the rad when the control valve is open. Back in the days before any controls, they were used to balance the system so that (at least to a decent approximation) so that when the control valves were open, each room would be heated "about right". In those days, the design of the system (sizing of rads in particular) and balancing of the system was an important part of any heating system.
These days with TRVs being almost ubiquitous, failure to design and setup the system properly is largely masked - and so (to be polite) "less effort" is put into those tasks.
But it's still very important - a wide open lockshield, especially if combined with an over-sized rad, will result in the system being unstable. What will happen is: control valve (TRV) opens (even a small amount), rad fills quickly with hot water, by the time the room temperature is getting towards setpoint the rad is putting a lot of heat out, room temperature over-shoots, TRV closes, room eventually cools down and cycle repeats. I strongly suspect that the operation you described earlier, where your TRV head shuts down well before the room is up to temp and then lets the temperature rise more slowly, is largely an attempt to deal with poorly designed and/or setup systems - and lets face it, who would want to deal with the support calls of "your eTRV head is rubbish" when it's the system at fault
I wonder if these energy saving organisations really know? ... We have seen so many daft statements, energy saving bulb for example ...
Indeed, it's one of those things where the statements are perhaps a little dubious.
Some times it not down to economy, it's simply what one likes, and in the main returning to central heating it's more about ensuring rooms not too hot for comfort than what it costs, and having hot water at turn of tap, and not having to wait for hot water to arrive.
I agree. The ultimate in energy saving on heating is to not have it at all and buy a load of warm clothing
Not really an acceptable proposition for most of us these days.
Programmable thermostats claim savings on your energy bill. But they can’t prove it. They make you punch in every temperature change you want throughout the day, and usually you can only program 2 or 3 changes. It’s annoying and complicated – most people don’t even bother. So despite their claims, most programmed thermostats stay at the same temperature all day. And that wastes energy. Programming just doesn’t work. So Nest found a better way. And a whole new way: it learns.
Do you believe that? It claims 10 - 12% saving, I am sure it does save some energy, as it stops the boiler cycling, but I would say most of the saving is due to the TRV scheduling, very little is down to Nest.
Here we see one of those "you need to read their assumptions and what they are comparing with. Most will assume a poorly controlled and poorly configured baseline - against which it is easy to show savings. But then, is such a baseline such a bad starting point ? One of the aims behind the OpenTRV project was to provide control for those (IME a significant majority) users who are incapable or unwilling to configure what they do have. I've met a lot of people for whom the simplest of time clocks is "rocket science" and a thermostat is something to be used as a switch (ie it's only ever on max or min).
Against that, a Nest is pretty well guaranteed to be an improvement - but it's not going to achieve the results that room-by-room control could do.
... so question with my central heating, do I really need a motorised valve? If I can switch down the TRV's do I need to have a motorised valve? The logic seems to say no, the TRV's do the same thing, and in the flat we have just 4 radiators so 4 x £15 = £60 and motorised valve is around £24 and needs to be fitted, however the motorised valve is hard wired and has micro switches built in, so even if 4 TRV heads are a better option in theory, in practice one can't auto control them and interlink them.
You've answered your own question there.
IF you can put a TRV on each rad
AND link at least some of them back to working the boiler, then yes - you can dispense with the zoning (motorised) valve because you are now splitting the system into a zone per room. If you are relying on a wall stat operating a zoning valve, then you are not getting the full benefit of individual room control.
Theory is reasonable easy if any TRV report target over current boiler runs, otherwise boiler stops, it really does not matter if TRV head is wifi, bluetooth, or hard wired, it should be easy enough to have a hub which reads all the data and simply switches boiler off/on
Yes, it
should be easy to do - but you have to remember that not one manufacturer wants an open and interoperable ecosystem - other than one based on
their system.
, in winter with in my case some 14 radiators one would always be asking for heat, so a modulating gas boiler would just modulated on return water temperature, and it would auto switch off in the summer. Practice is you can't buy a reasonably priced system to do it
So you end up having to BIY it to some extent
