- Joined
- 20 Dec 2010
- Messages
- 14
- Reaction score
- 0
- Country
Thanks for everyones replies so far...
In answer to questions
1) What was asked for was a system that would heat the house! With the capability of adding in solar heating/hot water. The solar side is a 'nice to have' as we do not plan to install the solar until next year. But we obviously need to have the heating working this winter!
2) What was promised was heating throughout the whole house, radiators and floor heating. In one room it was sugested that radiators would NOT be required because the floor heating would be more than enough to heat the room. Even with TWO radiators in the room neither floor nor radiators have reached any significantly noticeable temperature and ti remains very cold!
3) The pipework shown in the photo is pretty much all of it. The only two pipes that are not shown are on the accumulator one is said to be an outlet for heating the lower one a return. There are other pipes on the very top of the accumulator but I believe that they are for the solar system when installed.
4) Sorry I dont understand what pe x is? Is it good practice?
5) Yes that really is the inlet from the range that high up. You can follow the pipe from the tank back to the blue box which controls the water from the range. My understanding is that the inlet is that high up to create good stratification within the accumulator.
It's all very frustrating. the engineers left yesterday after modifying the system to take water directly from the accumulator to the floor but the pump only runs when water is delivered from the range and not all the time to at least TRY and pump hot water around the floor!
Since the modifications yesterday the system is WORSE as neither radiators nor floor are working at all.
In my mind the 600l of water should be delivered to the floorand/or radiators ALL the time or at least until a desired temperature is reached. Obviously if the water delivered into the deposit is insufficient to maintain the temperature in the accumulator then we are a bit closer to finding a solution but this way, without the abillity to deliver ALL hot water into the accumulator AND to run the pumps to push the hot water around BOTH systems then we are really not going forward in any way.
Look forward to hearing more useful comments and suggestions please!
