Hello guys, Hope you had a nice weekend.
Unfortunately
none of what the engineer did yesterday (cleaning the PRV, re-pressurising the expansion vessel (EV) - please see post #33)
helped - the pressure still drops from 1.2 to 0.6 bar after ~4 hours of boiler operation. However, the pressure relief pipe (PRP) outside didn't collect any water (perhaps ~ 2ml only), so looks like the PRV has been fixed.
The engineer said also that if PRV doesn't leak anymore after the cleaning - it might be worth re-checking EV for pressure and if it looses pressure again - it might be faulty and worth replacing.
My plan for this evening is to try adding Fernox F4 Express
Leak Sealer (
here) through the radiators would that be OK or would you rather advise to call an engineer again to check for a fault in EV first?
Also, I want to add Fernox F1 CH
inhibitor thru the radiator too. Is it worth doing together with the sealer, before or after - or doesn't matter?
Thank you
P.S. Just out of curiosity - EV has fixed volume so it can only take in so many liters of water. What happens when EV gets full - will it the water then escape thru the PRV or how? Thanks
