Recently moved house and have been unable to turn off the heating.
The heating system includes two centaurstats, a horstmann channelplus h27 programmer that all seem to feed into a Honeywell 42005748-001 Wiring Centre along with the pump, hot water cylinder stat and a Danfoss 2 port spring return zone valve. The valve is located from the output of the hot water cylinder (I guess the heating coil?) and then the pump which I assume pumps the hot water round the heating pipes.
I've tried turning off all the stats and the programmer but the heating remains piping hot. Should the honeywell wiring center be controlling the 2 port valve and close the heating off if none of the stats are demanding more heat? It looks like they previously had more zone valves as there are 3 redundant zone valves further down that have no head or wiring.
The plumbers I've had around so far don't seem to want to try and work out why it's happening as they see the redundant zone valves and say that's my problem but surely the zone valve that's wired to the honeywell wiring centre (wired as an S-plan) should still control the heating?
I'm not sure how these wiring centres are suppose to work but assume it's either this creating the problem? or the zone valve is not closing off? I've taken the head off the valve body and I don't see any movement when turning the heating off at the clock, but also if I manually turn the valve it still stays hot.
Any ideas would be much appreciated.
Thanks.
Thanks.
