My house has 1.96m ones, with 2.45m ceilings - I don't see how, say, 2.35m ceilings would be so appalling as to make cables visibly clipped to the ceiling look better.
Cost and effort of all this false ceiling though and to change door heights and to avoid nailing batons into 15cm zone already with wiring ...
A proper solution?You guys must be builders . All I need is a proper solution ...
I can offer you 3
- Lower the ceilings enough to be able to conceal cables up there.
- Learn to like seeing cables clipped to the surface of your ceilings.
- Sell the flat and buy somewhere without solid concrete ceilings.
There are more solutions. I'm not sure about D trunking, but someone suggested it ... happy to hear more, apart from the naff ones . I'm unlikely to sell a flat just for an issue like this, but yes, that's a solution (in the extreme). I could put some mirrors up there and some wall spots and get the angle of incidence right, that's not too bad, could add an adult dimension to romantic dinners ...
(regarding the PIR comment: I have all the circuits and the installation documented and even photographed, so as long as any future owner doesn't lose these, everything should be clear - yes and of course it will be inspected, no I can't do anything too unconventional as this probably won't get passed)
