And one that has some coloured smoke pellets - grey is no good against a cloudy sky
I am registered for gas fires and I am the first to admit I would be the last person to call to work on them,cant see how if the TV bracket bolts entered a standard Chimney how it would affect the pull in any way, piercing a liner? cant see it to be honest but stranger things have happened, as already said just voicing my opinion , I would go with FiremanT he is the authority on fires on hereRather less than some recent electronic devices or tumble driers
You seemed to have focused on the last resort than sorting the root.
If smoke goes IN the chimney, it will come out. Somewhere. The flue could be damaged in the loft,filling the loft with smoke (and fumes when fire on, and poor flue pull). More likely the wind was blowing the smoke in a position not visible to him. I have in the past done several smokes, while repositioning myself in the front/side/rear garden. Over the road, and standing on walls. Did any smoke enter the room in which the fire is located. ?
Most fire jobs are straightforward, it is the awkward ones that seperate the experienced, and the thinking, from the clowns
First, get an RGI that is registered AND experienced with gas fires. Explain what happened and ask for him to retest and give his opinion
wouldnt surprise me if the guy doesnt even have fires on his ticket .
OP do not pay the bill guy sounds like a chancer
I would guess the guy did not know how to interpret the test, or have any experience of fires and chimneys.
He says he is not sure if all the smoke came out? Where the heck did it go, then. Did he check in the roofspace?.
If the "pull" was sluggish, did he preheat the chimney?If there is a problem, it is more likely to be with, say, a cobweb (seriously!) or birds nest material than a handful of bolts. I could go on, but you get the idea.
Also, before I started chopping bricks out to investigate a bolt, would it not be simpler just to remove the bolts, and use a prodding device to see if the chimney is breached?
Also, the TYPE of chimney is significant. If the tenant does not use the fire, then why not remove it, and save some annual fees?
