- Joined
- 4 Sep 2022
- Messages
- 625
- Reaction score
- 3
- Country
Is it the Chinese junk modal in question or the German Webasto?My car has one, fitted as an option. They work great.
How long have you ran it for?
Running the fuel though a copper coil output of the heat output to pre heat the waste engine oilWhat is coiling it?
Dose it have 2 heat out puts then, one air and one water? do you think over all on run time its less then 5amp?My heater runs on 12v, draws around 20amps initially, when starting, for the glow plug, just to get it going. That drops down to just the few watts needed to run the combustion fan, and in my case, a water circulation pump. The water pump is needed, because it heats up the engine coolant, to pre-heat the engine.
Yes I do plan to twin tank itIf you intend burning waste oil, they usually suggest using it premixed, with diesel. Start it, get it going on diesel, then swap to a mix of diesel/waste oil. Maybe worth having two such heaters, one in use, one offline being cleaned and serviced, if you want reliable heat.
