But it wont start the machine though. What size is your battery that you start your Webasco with may I ask? Cold cranking or leisure battery type?
It's an 80 amp hour.
Our man from the battery shed says that these new jell absorbed glass matts are all the rage now. But double the money of the older type of LAB.The Eberspacher heater did have a low voltage cut out, I would think most do, as to battery voltage, I have in resent years had to revise my thoughts on damage to batteries due to over discharge. It does depend on type of lead acid, for a traction battery or absorbed glass mat or valve regulated lead acid they seem to survive deep cycling far better than the vehicle start battery,
So a cold cranking battery has thicker plates and in turn more space between each plate and thus easyer for the sulfer to drop off?to get the high amps to start an engine yet keep the battery small, the way the spongy lead is held on the plates allows it to fall off with deep cycling, the leisure battery is a hybrid, not as bad as a vehicle start battery for loosing the material, but worse than a traction battery.
And what do you recon to this diesel heater in question wanting to draw 12 amps just to power the glow plug. cold cranking battery better then leisure battery?However load will drop the voltage on a traction battery much more than with a vehicle start battery, so where a battery needs to do both, a leisure battery needs to be 1.5 times the size of a vehicle start battery where used for duel tasks, like in a motor home.
My leisure battery is 110amp/hr. But dose not hold 12v wellSo question is how long and what size is the cable used battery to heater? Is this causing the volt drop, what size battery is being used, 40 Ah is minimum size for a caravan "A721.55.3.2 Capacity" and I would say in the main smallest used is 90 Ah, I would use smaller I have two 35 Ah AGM batteries for the mobility scooter and likely they would be OK where there is normally a mains supply, but would need a smart charger so stop over charging.
Is this something to do with ohms law or something?You have replied while I was writing, Volt drop calculator here clearly you need to know amps, and it does not do 0.75, but I used 1 mm and 5 amp at 20 meters and got 3.7 volts which would be enough to cause problems.
Are you using the car battery or you have leisure battery?It's an 80 amp hour.
I think nearly every time you post you demonstrate another limitation to your understanding that impedes you with regards to doing electrical work safely and sensibly. Thankfully we're only dealing with 12v hereWhat do you think? Do you think it will give me 3mm2 wire with out putting to much resistance up?
So we go back to what our friend erricmandodar states about car starting battery needed as opposed to leisure batteriesMy car is fitted, with an 80amp hour battery, which power both car, and Webasto.
ok this thread is not going to answer my question on how to deactivate it
So rather then spend another 56 quid on a battery I think I will just send it back for a refund and forget about it!
You are obviously not aware of the advice I give on this site, I go out of my way to help those who come here for help and advice and sometimes I look for ways, let's describe as unorthodox or non standard, to get something working safely or to avoid major upheaval works.You know your problem dont you? Your just one of those jobs for the boys men, think he will make a livelihood out of bureaucracy. But in reality he dose not see the bigger piture as everyone looses in the end
