Hi guys,
Thanks again for the replies. I may come here more often.
Paul_C,
I appreciate your point about testing any point in the circle, but when I imagined testing I was thinking about testing a complete or current installation. If you test at a socket or junction box anywhere for continuity around the ring then you already break the ring at your point of test. So the only way to test the whole ring is to break in at the MCB, otherwise your testing 2 halves of a ring connected at the CU. Plus from that point you can move around the ring from socket to socket until you get continuity and at that point you know you have just passed the bad connection. Not sure if that makes sense to an electrician, but it does to me
PrenticeBoy,
Yup the board is RCD protected, or at least half of it is. The house was supposedly rewired in 1999 so most of it isn't that old. There are just odd bits which I am surprised to see considering the house was rewired. Such as a round pin plug from ages ago connected to a lighting circuit and unnecessary junction boxes. I have started to get the impression that some wiring was done and the CU was changed, but I don't really think it should have been called rewire.
JohnW2,
What you say is pretty much how I had taken it. I just wanted someone elses opinion to improve my confidence a little. Basically I want to extend the ring to put a socket up to the loft and possibly another that will require taking the ring further into a rear bedroom.
Cheers
Kenny
Paul_C,
PrenticeBoy,
JohnW2,
Cheers
Kenny
