Class 1 Light without earth on supplied plug
... it looks like a wall light poorly converted using the hole in the base, for the flex, maybe originally for a pull switch
Althjough only one product seems to be on offer, the photos in the Amazon listing (click here) appear to show two variants - one with a pull switch and the other with a cable coming out of that hole with an in-line switch and a plug (in one illustration a 2-pin plug). All are 'wall lights'.
Kind Regards, John
The lack of earth is dealt with in a customer question who is advised that if using a plug in method a "ground" wire is not required!
Blup
The lack of earth is dealt in a customer question who is advised that if using a plug in method a "ground" wire is not required!
Blup
Yes, I said that in my OP, but I think this is a misinformed and incorrect response! That is why I came on here to ask, and several people have agreed - that answer is simply wrong!! Are you suggesting it is correct..?!?!
It definitely is not correct. As you must know it is yourself, the listing indicates that it is metal, and it is clear from your photo that it is not 'double insulated' - so it must have an earth, regardless of how electricity is supplied to it ('plugged in' or 'hardwired').
Kind Regards, John
Agreed, sorry, just that Blup's comment seemed to suggest otherwise... I am guessing it was maybe sarcasm, that doesn't always come across in a forum post!
:D
Agreed, sorry, just that Blup's comment seemed to suggest otherwise... I am guessing it was maybe sarcasm, that doesn't always come across in a forum post! :D
True - I think the exclamation mark at the end of blup's statement was probably meant to indicate that he found the suggestion to be 'extraordinary'/worrying/dangerous !
Kind Regards, John
Kind Regards, John
Oh yeah, thanks.
To be fair, they look quite good for the price, its just a shame the wiring lets them down, i personally think there worth amending, though I personally would not want a flex out of them showing.
Oh yeah, thanks. To be fair, they look quite good for the price, its just a shame the wiring lets them down, i personally think there worth amending, though I personally would not want a flex out of them showing.
There's obviously no reason why there has to be flex coming out of the hole - they could be 'conventionally hard-wired. Indeed, most of the illustrations (including, obviously, all those showing a pull switch) do not show a visible flex supply.
Kind Regards, John
These fittings supposedly have UL certification.
It may be worth getting in touch with them.
The Amazon listing certainly says so, but I see no UL marking on the label of the OP's item. It does have a CE marking of some sort, be it 'real' or otherwise (but that only relates to 'self-certification', anyway).
Kind Regards, John
Not sarcasm.... Maybe the OP could leave an Amazon review pointing out the defect
Blup
He most certainly should. It seems that Amazon have aided and abetted
Shenzhen HOXIYA Lighting Co., Ltd
No. 10, Ande Street,
Meiting Community,
Meilin Street
Futian
Shenzhen
518000
to encourage the OP to import a dangerous electrical appliance that does not meet the electrical standards of the UK.
Unfortunately they will continue to do this as they have deeper pockets than most.
