Oh BTW, one bloke in Devon has not heard of how to use tiles below their minimum pitch and swears that no one else down there has either. So to be safe this method only applies to the other 47 counties of England, Wales as a whole any most likely Scotland too.
When a builder is told by a supplier that a roof tile won't be available for 6 months, what is the best option? Find a suitable alternative or use any tile he likes and try to wing it?
I'm, minded these days to look at the max roof pitch achievable and work from there. Designers often don't stipulate a tile, rather they say match existing or some such. Designers can also assume the wrong pitch or draw it in a way that works on paper but not in reality especially when the pitch is down to the knuckle with zero wriggle room. I just think your suggestion is a bodge, sorry.
Sometimes, it may be preferable or even required to use a tile below it's minimum pitch for various reasons. So its good to have the option rather than a less favourable alternative.
One such situation is that of the OP.
So despite the traditionalists, or those with a point of view which may be valid, or inexperienced "designers" who only have a narrow concept of their job, its always good to have the options available for when the circumstances require alternatives. That is design.
But proper plan drawers work things out beforehand and specify the appropriate tile to satisfy planning criteria, the pitch of the roof, building regulations and any client requirements.
They don't just leave it to the builder to get whatever tile is on special offer down at the merchant's.
You've obviously never worked on jobs where the roof had to be done in a specific way for specific reasons. Like conservation or listed buildings or other planning restrictions.
So best stick to your limited area of knowledge, not comment on stuff you know nothing about.
Lol listed buildings or planning policies can all be built whilst keeping within suitable manufacturers recommendations. A good designer will always be able to eliminate inappropriate construction methods at the design stage.
Agree with Freddie - surely at the design stage you would design problems out not in? Especially when you consider that you are making the job poorer and more expensive.
