Clipping cables to thin metal beams?
12 Oct 2011
Wirral
I'm after putting up some lights in my steel fabricated garage, the frame work is press w-section beams in about 1mm steel and im wondering what the best way of securing the lights and cabling. For the lights themselves I can use self tapping screws into the frame as used to secure the cladding but that appears a little over kill for the cable, and although some rubber sleeved p-clip's or similar but I would also prefer to secure it on the topside so its better protected. I wondered if there are some knock-on type clips that would do the job, ive seen them for use on 5/6mm i-beams, but obviously they wont grip down 1mm thick material. Ideally im sure it would all be in conduit but I would rather avoid that if I can.
Something like this ??
http://www.cablinginstall.com/articles/2012/10/magnet-cable-clip.html
No idea how expensive they are.
I just used some girder clips with bolts that will clamp on any thickness, have a look at britclips
Opinions on: MET bonding of this metal framed garage please.
As always, that will depend upon the impedance of the path from the structural metal to earth (I would personally say, under very wet, as well as dry, conditions).
Kind Regards, John
Is it penetrating the ground and if so can it introduce a potential different to the garage's earthing system ?
If it penetrates the ground and provides a reliably-low-enough impedance path to ground, I guess it could theoretically be used as the garage's earthing system, which would avoid any need for bonding!
Kind Regards, John
So is this compliant with 411.3.1.2?
Sure, IMO. 411.3.1.2 requires bonding of extraneous-conductive-parts, and then lists examples of things which may be extraneous-c-ps. If something is not an extraneous-c-p, per definition in Part 2 (and per ricicle's thinking), then there is no requirement to bond it, even if it's one of the things in that list.
You presumably are not, for example, suggesting that all central heating systems need main bonding (because they appear in that list in 411.3.1.2), given that (at least in domestic situations) it would be extremely rare for them to be extraneous-c-ps?
Kind Regards, John
