Clipping cables to thin metal beams?
You could, of course, always slip in little scraps of (1-2mm thick) metal (or something) under the clips, to bring total thickness up to ≥2mm.
True. I'll add some to the order and see how it goes.
A good source of such 'scraps' might be bit cut from self-adhesive cable clamps (they cut easily with tin snips) - since the adhesive would then keep them in place whilst you attached the clip proper.
Kind Regards, John
