Thanks so much for your replies guys. I'm so glad I joined this forum. Just to be clear - This is a large-semi with 4 bedrooms and there is no loft - It's a proper attic with stair case - Again freezing cold, but it's got floor and roof insulation. A portion of the property (The Hallway) has a very cold coal basement and the rest has a suspended floor.
I'll try answering as many of your questions as possible.
I've got loads of photos, but it won't let me upload more than 20 images....is there any other way I can show them, such as direct links to the albums?
- Funny enough, I've already done the joss stick technique quite recently. I found there is a draught mainly coming from:
- The bottom of double-glazed window frames/window sills in almost all rooms
- Edges of upvc doors / french doors
- Edges of part suspended floor/skirting boards
- The Bay Window area is very cold and draughty - In fact it's so cold that we regularly get large amounts of condensation on the windows during winter....is there something missing?
- Not sure what you mean by the issue within the loft space...this is a proper attic with a staircase...however it's not in use and it's absolutely freezing in there. However the whole attic floor has had rock wool insulation between the floor joists.
- Also not sure where you are referring to when you say "why is there a light colour on the image that is following the roof line in the loft?". Don't suppose you could post towards it?
- If I'm correct, the dark mark below the bay window that you're referring to, is actually an outdoor bench
- Yes, the neighbour to the left has a gas fire.
- As far as I know, the neighbour to my right has had cavity wall insulation. However, when my property was about to be pumped with the same stuff, a BBA surveyor turned up to do a random check and stopped the job - He said these properties need to breath, hence no insulation allowed.
- As far I am aware, the radiators in all rooms are the correct size.
