If the problem is caused by the prv, you may not see the water coming out. Stick a sandwich bag over the outlet and secure it with a rubber band. One second look in the morning will tell you all.
I too have this problem? Mine started because the previous owner had put a screw through the pipe which lead to a burst pipe when I was walking around on the bare floor boards. ever since I repaired the pipe though the pressure always seems to be very low and the pipe that leads outside always seems to drip ?
