Do you have any independent data to back that, at first reading, ludicrous statement up?
Isn't common sense enough?
I hope so.Isn't common sense enough?
Thanks, yes I am finding everyone wants to do a combi with seems at odds with online advice.
Why would this be?
If we stuck with a standard boiler, would there be any point/benefit in replacing the tank? We have a 30+ year old beast with no kind of insulation like they have now.
at point of use would compare unfavourably with a high efficiency low mass, modulating, low water content
low water content primary and secondary heat exchangers separated by less than 400mm of pipework with primary water moved at high velocity and used only for short periods on demand.
The difference is what exactly? On a gravity system there is some small heat-loss while ever the boiler is trying to heat the cylinder, then it is done. With a combi, there is more wastage heating the boiler and water in the boiler, but every time there is a demand for hot water. Seems six or two three to me.
A heat only boiler is what you refer to but I'm 'almost' positive you cannot buy a gravity boiler and if you did you would be in breach of building regs to install it.
A system boiler is basically a boiler containing all the components of a combi except the hoy water section and diverter valve. It's pressurized and has pumped primaries not gravity primaries.
A heat only boiler is the same as a combi less the hot water section, pump and expansion vessel.
They all have electronics and are far more complicated than a gravity boiler.
By gravity I assumed you meant a system with a F/E tank on the boiler circuit, as opposed to an expansion vessel. Not an old-fashioned system with gravity HW, pumped CH. As we all know, there's pros and cons with F/E tank and expansion vessel.Yes, my apologies, I got the word 'gravity' into my head, but not withstanding - I standby what I said..
No chance of that from a new boiler.o with a possible £500 a year saving
Or we could have a fire pit in the centre of the house, remove all doors and windows then get rid of the first floor and remove a few roof tiles to allow the smoke to escape.Your installer will want for various reasons to persuade you to convert to a combi. A gravity system already installed, has many benefits and would cost you a lot more than a combi to install, if you were starting from scratch. If what you have is in good condition - keep it, just replace the boiler.
Despite modern boilers being able to modulate, a gravity system (depending on how you use it) has potential to be run more efficiently than a combi. As above, you may also have the benefit of an immersion heater with a gravity system, should the boiler fail.
yeah not having hot water for the 1 day they are renewing the main in your lifetime should be the deciding factorWe are having new gas mains in the village, people with gas combi boilers may have no means of heating water ( other than a kettle ) while their gas service is not available. Those with a hot water cylinder probably have the option of heating by electric immersion heater.
Not only loss of gas supply but fault in the boiler, it could be days before it gets repaired,yeah not having hot water for the 1 day they are renewing the main in your lifetime should be the deciding factor
As with any boiler and its is not unusual for immersions not to work when they get used years after they are fitted .Not only loss of gas supply but fault in the boiler, it could be days before it gets repaired,
Boil water in a cauldron over the fire for efficiency!
I agree Bernard. The old ways are the best.
