His neighbours might, god help them.You seem to have your mind set on what you want to do so why ask for advise if you won't listen. Some good points have been raised.
Just do what you think right. Who gives a fk
Why are you bothering to post on this forum then?
If you believe/know what the op is suggesting is dangerous then although commendable you shouldn't be so snotty about it. He is more likely to take note of what you have to say if you are civil.
Also, don't start bragging about what quals you may/may not have it just makes you seem like a total fat head.
The flue outlet on the boiler is 160mm square so had to fabricate an adaptor from that to 145mm circular.
The 160mm is outside measurements. The plating is 6mm.The flue outlet on the boiler is 160mm square so had to fabricate an adaptor from that to 145mm circular.
What you have done is make the flue 35% smaller. Good start
Thought you didn't give a f**k?
No vent. T&P is the vent.
Where are the vents on these boilers?
