White socks, leather sandals and tan shorts ending 1.25" above the knees is the image I have.
Thanks for the responses. I think you've sold me on sticking with the idea of unvented. If I site the cylinder in the downstairs utility room then space isn't really an issue. I presume that doesn't change the complexity or performance other than meaning that that circuit would need to be pumped from the boiler rather than gravity.
And, as for meeting regs???
perhaps you should go with more conventional systems that the day-to-day tradesmen on here advocate
described the system to WRAS and asked for their comments,
Their opinion is that tt does not contravene any regulations (or any reccomendations) and is therefor compliant and acceptable to WRAS
or the systems that have proved themselves reliable and effective over many decades. They are the conventional systems.
,would be safer and cheaper to fit a combi
And that’s how it is.
Which yours is not.
for the majority of properties. But not all properties.
It is conventional but with the addition of a passive heat exchanger to achieve mains pressure hot water to the shower.
so having an untested,unapproved wras adhock diy cobbled together system is acceptableAbsolutely not. There is only one place that the boiler could be fitted and from there to the bathroom is an 11 metre run of pipe. The waste of water and gas while waiting for hot water to travel the 11 metres would be totally unacceptable
Thats not a problem with modern installation techniques which are not available via googleThe waste of water and gas while waiting for hot water to travel the 11 metres would be totally unacceptable
Would that be 8mm micro bore pipe?Thats not a problem with modern installation techniques which are not available via google
