- Joined
- 11 Apr 2017
- Messages
- 13
- Reaction score
- 0
- Country
Gents..
I'm after a few answers to what would be simple questions to the "experienced" around here..
I'm a novice, I don't dispute that however I've recently purchased a 1970's Dormer bungalow which hasn't had any work carried out since the day it was built. My budget is limited so looking to do as much of the work as possible..
With regards to the CH system, I think I'll be going with the Worcester Bosch 38cdi which I'll have a Gas Safe technician actually install, however I want to run all the pipework prior to the install to cut down costs etc, now what i'd like to know is....
*** - Pipework diameter from the boiler for domestic hotwater, if it's 22mm I presume it reduces down to 15mm prior to the taps.. is there and where specific to reduce it down or do I put a 22mmx22mmx15mm tee and come off that way to each HW tap and then do I cap the end of the pipe?? (2 questions in that 1)
*** - Pipework diameter from the boiler to CH (OUT) to the radiators... again if 22mm and the rads are 15mm would I just do the same set up as like I do for domestic hotwater??
*** - Pipework diameter, radiator return pipework back to the boiler??
*** - Domestic cold water.. again piping diameter from boiler around the house to the taps?
*** - Running the CH radiator pipework from downstairs to upstairs... is that just a case of tee from the outlet feed and send it up through the wall to the upstairs rads?? I presume it'd be the same for the CH return from the upstairs rads.. One pipe flowing up & one flowing back down?? Again, what diameter pipe to use.
Any and all help / advise would be much appreciated. Even if you could only answer 1 question... it's better than non.
Thanks in advance.
Thanks in advance.
