Composite door "shudder"
No amount of extra fixings will make a difference (assuming he has done the recommended 600mm fixing spacing when joining the frames).
This is due to the flex in the 3 separate frames and the aluminum couplers.
I have the exact same problem
Front Door with two narrow side panels in glass. The door is fitted properly and strapped at 5 points overhead but there is still a shake
I have not rendered the outer reveal overhead yet, so I presume I will need something like this, which is strong but flexible enough to prevent cracking?
I will also need mesh I presume
This would create a solid front for the doorframe to press against. On the inside, I may consider angle iron fixed up to the lintel across the width of the frame. This should prevent any play or movement?
What problem does it cause? Does the wind shake it audibly or is it just the few times a day the door is used you notice a flexing?
