Hi
I've put a new TRV onto a downstairs rad, had to drain the entire system and now i've put it all back together and refilled, there is still a very slight weep (culminating in a very slow drip - 10ml overnight approx) from both the copper pipe compression fitting and the TRV body to rad compression fitting.
I have already nipped them up, but as the pipe is at a slight angle as it enters the compression fitting due to being a bit short, I think that might be part of the problem. Also the pipe only goes in as far as the olive (maybe protruding about 2mm or so).
Is it OK to keep nipping up until watertight?
Otherwise I guess i need to drain down system again, and then extend the pipe, which leads to my next question:
Is it OK to extend the copper rad pipe using a compression fitting? I was thinking of using an isolation valve. I realise it may not look the best, but I cant solder.
Any other suggestions very much appreciated!
Mike
Mike
