Hi All
Problem with condensation; sorry, not strictly a plumbing or central heating question.
We recently had a multi fuel stove fitted in our lounge to replace a coal effect gas fire; partly for long term fuel savings, partly for reasons of sustainability, and partly because we had hoped it would allow us to heat the cold, flat roofed front garage conversion bedroom in our bungalow. I intended to do this by leaving the door open from lounge to bedroom when the stove was on. Instead, it seems to have created an unexpected problem.
I have the stove burning tonight and I've open the door to the porch, which leads to the front bedroom, to allow the stove to heat both rooms. When I went into the bedroom to check the temperature I found that all cold surfaces, mainly walls and window but also wardrobe doors, were streaming with condensation. So much so that the matt paint finish on two of the walls appears to be developing a patchiness. The room is normally unheated when not occupied, and although it gets cold because of the uninsulated flat roof and we've noticed a mouldy smell in one of the wardrobes after the end of winter there's never been anything to this extent.
Could it be that some of our firewood is damp and that damp is transferring itself to the atmosphere and then finding its way to the walls of colder rooms? Any other possible reasons why we might have this issue since installation of the woodburner? I could apply anti condensation paint to the bedroom walls, but that would be sure to transfer the problem elsewhere.
Thanks in advance.
Thanks in advance.
