I let out a 3 bedroom mid-terrace 1965 built house.
It has UPVC double glazing which is quite old but as far as I'm aware, generally functional.
The family (2 adults, and 4 small children) are complaining on excessive condensation in the kids bedrooms. The box room in particular suffers quite badly from this.
Yes, I have told them (currently blue in the face) many times about heating and ventilation but they claim to do all this.
Aside from the fact they may be bending that truth a fair bit and the fact there's a large number of bodies and associated moisture build up, is there anything I can do to help???
In the worst room, the condensation is not just on the walls but on the internal side walls (90 degrees to the window). A mate popped round and said that those sections of walls were getting quite cold, hence the increased condensation. Those sections of wall internal and out are solid - no cavities. So I thought maybe, where the window frame sits in place around the outside, there is a cavity, causing the cold walls internally.
Not sure whether the outside of window frames where they connect to the wall should be insulated with foam or whatever? Ideas?
I can get those windows changed but to be honest, I've got a feeling that won't make any difference? Opinions?
At the end of my tether with this now.......
Want to resolve this issue and help the tenants but I've run out of ideas.
Problem is, they claim they are heating it enough and ventilating it enough. I've said whatever they're doing isn't enough. Going round in circles.
Just wanted to know what I can do to help with this???
