I walked through the flow chart. Did you read it? Everything I write is 100% correct.You've not said a single VALID reason for being exempt.This is hilarious Some here have no common sense whatsoever. I even wrote the flow chart out for you, and others, and walked you through it explaining how it works and how it is exempt.and it is exempt
No, it isn't.
You fail to see that I CANNOT fit a plume kit or condensing terminal discharging onto the common landing at head height whether I like or it or not. I simply cannot fit the plume extension kit across someone else property. FULL STOP. Can't you see that? I cannot fit one.As I stated, not liking the look of either the plume or the plastic flue is not reason enough to be exempt. Whether it's you personally or the building owner is irrelevant.
I do. A non-condensing model. The regs say I can. Look at them.You do not have the RIGHT to have a gas central heating boiler installed.
Let's face it you never knew the regs until reading this thread and thanks to D Hailsham for that. I assume you have been fitting in condensing boilers when you did not need to, all this time. Now you know so you can do it properly next time.
Stop trying to save face. You are making a fool of yourself.
