Officially it's 120V in the USA and 230V in the UK.The electric fire analogy above is incorrect. USA electricity is 110 volt and ours is 240 volt. Thus their voltage is 46% of ours.
Agreed W= V²/R; though this is only strictly true for DC. If AC is involved you have, in theory, to take into account the inductance of the coil of resistive wire forming the element of the fire.Reduce the voltage by 46% and you reduce the current by 46% as well. The power output is therefore 46% of 46% which is 21%.
Whilst this is correct in theory, the resistance of the heating element may vary with different operating temperatures, and the actual heat output may be different from the predicted output.
Again, I agree. It was a simplification which assumed that the differential was 10C. Double the differential and, for the same output, you halve the mass flow rate. Which, unless you take into account the change in density of water with temperature, is for most purposes the same as the volume flow rate as one litre weighs one Kg at STP and the error is less than 3% at 80C.And finally - the output from a radiator can be calculated by measuring the mass flow rate of the water and the temperature difference. You would need to know both values.
In my defence, I would like to point out was 10:30pm and I was being pestered to finish my supper and have a shower.
Doesn't exist! There are three possible contenders: Defra; the Environment Agency; and the DECC (Dept of Energy and Climate Change).mysteryman said:The advice not to oversize rads is from the DoE.
So which one issued this advice and where do I find it?
