Would it be acceptable to connect the cable for a warming drawer to the same cooker outlet connection as a combination microwave?
The maximum load of the warming drawer is 0.43 KW. The manufacturer specifies a 13 amp fuse. I dont know if the warming drawer comes with a moulded 13 amp plug, but in any case it would be cut off and connected directly to the cooker outlet socket.
The M.W. has its own radial circuit on a 16 amp MCB on the RCD side of the C.U. with 2.5mm cable to a 20 amp switch and 45 amp cooker outlet.
The max load for the MW is 3.4 KW. The manufacturer specifies a 15 amp fuse.
