Just bought a 1960's bungalow (2 bed, kitchen, lounge, bathroom, hall. All on one (ground floor level)). House was re-wired about 1992.
The existing consumer unit is a 100 A unit. the circuits are MCB protected and assigned as follows:
Heating 6A
Door Bell 6A
Lights 6A
Water Heater 16A
Ring Main 32A
Ring Main 32A (ie there are 2x 32A MCB's labelled Ring Main)
Total 98A
I'm refurbishing the kitchen and bathroom and intend to replace the 2 "Ring Main" MCBs with RCBOs but I also want to install extractors in the bathroom & kitchen, an electric oven (currently gas) & gas hob and run a supply to the garage.
Can the extractors, oven & hob be run from Fused Connection Units on the ring main or do they need to be separate supplies?
As the total capacity of the Consumer unit is 100A does this mean that tha load capacity of the MCBs added up must be less than 100A or can the total capacity of the MCBs exceed 100A provided the load doesn't exceed 100A ie can I add a 16A MCB for the garage giving a theoretical total of 104A.
Can any of the heating / door bell / water heater circuits be combined with the ring main circuits (ie install FCUs on the ring main to power these items) or can the 2 ring main circuits be combined into 1 to provide the "extra" capacity I need?
F
Heating 6A
Door Bell 6A
Lights 6A
Water Heater 16A
Ring Main 32A
Total 98A
F
