It might not be a bad idea to replace that old wylex fuse box with a new CU with a properly sized main switch, and that way you could also include RCD protection for your sockets (which you currently don't be should really have)
I would like a new CU, in fact I was looking at them in
Wickes the other day, although I wouldnt of bought one then and there without a bit of research.
But to be honest, although I dont anticipate any problems in doing it, I am not certified and wouldnt know how-to or have the equipment to test it properly after doing it, plus that comes under part p and needs inspection (although so does this room if its not just an 'extension' of the ring mains). So I have put the new CU idea on the future-things to do list ie. I wouldnt mind going on a course to do it legitmate but I have no idea of what courses I would need etc..
Same goes for the bonding issues I showed in the picture, I will just re-connect it all up but it does need proper testing and apart from a simple earth continuity test I dont know how to do that.
Simple solution is to get it inspected etc. but I would have to do that for the CU , then the bonding etc.. I would like to do it myself but do it knowing im doing it correct (and legitimate to some level). Oh and the fears of house-insurance voidance.. (I really dont know how that works!). What you guys think?
There is still the shower to sort, in fact I bought it a while ago (wife cant resist sales!) but when I get to that I was planning on putting an external rcd off a fuseway (a quick solution). Think we are going to do the bathroom out first at the moment im having a lot of small baths!
I think because a shower alreay exists I can swap it out legally. But if im adding and RCD I guess its not legit then, although safer but if I can connect a new shower ok then surely I can connect and RCD safe (no time for reg rant now
Case is burgered...
Why a ring for a room on its own? Wouldn't a radial have done? or will you be extending it in the future?
Case is just cracked, its had a supergluing and what you see is just cosmetic.
Yeh the room would of been ok on 20a radial but I didnt really think about it until now, as ive had to built a wall, plasterboard, sockets, skim etc. to get to this point . No plans on adding anymore sockets but a ring is better so i done that!
