- Joined
- 11 Jan 2004
- Messages
- 43,992
- Reaction score
- 2,896
- Country
Bovis
They make good bread, too.
Bovis
Possible, if the new boiler was fitted in a convenient location to use the old immersion heater feed. Just pull that fuse and see if the boiler stops working......immersion...now its a combi boiler....do you think it may be on the 15 one now
You mean a fuse intended to fit a 13A plug in your consumer unit?in fact what would be the problem fitting one of these instead of a cartridge fuse of 5A rating
The fuses for plugs are to BS1362, while those for the consumer unit are BS1361. They're different physical sizes.
The BS1362 fuses for plugs are all the same size from 1A right up to 13A since they all have to fit the same fuse clips in a BS1363 plug. The BS1361 fuses are different sizes depending upon value. While the 5A isn't far off the size of a BS1362 fuse, it's still different.
If you are going to do a job properly…
mrcrow
If your boiler is on a 15A fuse, you could extend the circuit and fit other sockets to it. Then if you do get a new board, it could be upgraded to 20A.
i have moved into a 1988 2 bed bungalow, and the consumer unit has 4 mcb's for the house circuits
the values are...30-30-15-5 amps
i am going to find out which circuits are relevant for the 2-30's and assume the 15 is lighting
what could be on the 5 amp mcb
there is a socket in one of the kitchen wall units for the hob extractor?
there is a socket in one of the kitchen base units for the fridge?
there is a central heating gas boiler?
cheers
geof
