I think the fact I’d read them as 1.5x confused me and caused me (incorrectly) to assume that was the factor.No problem.
If your typing fingers had obeyed you and typed "1.7", you probably would have noticed that what they recorded was '1.5 times' - which might possibly suggest that not only didn't they measure R2, but that they calculated it using the same incorrect figure that you actually typed! For them to have actually measured R2 as only 1.5 times R1 (or Rn), for both circuits, would seem to be rather stretching likely co-incidences!
Kind Regards, John
@jagillham if I’m honest the NICEIC probably won’t be all that bothered - as far as they’re concerned the figures could be accurate. And to an extent, an installation certificate is like an MOT, it’s only really accurate at the time it was testing. Readings can and do change over time so even if it was retested and different readings obtained - it’s entirely speculation that’s the figures are fictional. A pretty safe speculation, but speculation nonetheless
