- Joined
- 11 Jan 2004
- Messages
- 46,038
- Reaction score
- 3,575
- Country
I don't.the more I look into it I find it hard to believe the guy could leave it like this
I don't.
I'm afraid it's quite believable when people who aren't actually electricians take on work like this.
I had a Electrician replace my old metal fusebox with a modern consumer unit I got from Screwfix and I am really not happy with what he did but once he started I had no option but to let him finish as I need an electric supply as I work at home via the internet.
Now my flat uses steel conduit as the earth and uses singles for the mains and lighting.
After yanking the old fusebox off the wall with a crowbar and pulling half the plaster off the wall and cutting all the insulation of the singles in the process. Hence the shrink wrap insulation on all the wires to repair it.
Forget about the nearly setting light to my flat with his dodgy extension lead which had a cut live wire in it and started sparking with flames coming out on my carpet. luckily his assistant picked it up and held it off the floor while he hurried to disconnect it.
What an absolute nightmare that was.
My main concern now is that my flat wiring is now not safe as the earth termination has been removed.
The conduit where he cut it with an angle grinder has very sharp edges and when I suggested deburring it he gave me a funny look. although after my insistence he did attempt to deburr them.
I am getting an inspection done and then have to rectify it but for now I have put earthing straps on the conduit.
I am going to have my flat rewired replacing the singles with twin and earth.
Surprising after all his work he refused to issue a certificate saying about the earthing and a mains ring being broken. If he had mentioned this problem to start with I would have told him to leave it while I look into what to do.
I am scared to get another Electrician into fix it now but I know I must.
Hi Guys
Almost there with my parts etc, just waiting for a die stock to arrive so I can put my M16 thread on my 5/8" conduit.
I was wondering about my consumer unit when I redo it so it has proper mating with the conduits etc about moving the tails entry to the left hand side of the consumer unit to a 32mm knock rather than the two 20mm knockouts he put them though on the bottom right of the CU.
As this is much closer to the meter and prevents the long lengths of the tails below the consumer unit. I would also use a plastic gland for protecting and fastening the tails and earth through the knock out.
To do this I thought it might be best to rearrange the dual pole switch isolator to the left of the CU, I assume this would be OK ?
I never knew about all this and the regulations but the more I look into it I find it hard to believe the guy could leave it like this as I could have got the bits he needed from the screwfix just up the road like I did with the heat shrink insulation.
Get an up front isolator fitted before your cu, then you can isolate whenever you like.I guess I need to go around checking out each socket first of all and checking the conduit continuity between them to check out the overall state.
All this just because I wanted to put a bathroom fan in and I thought if I am getting someone in to do it I might as well get them to replace the consumer unit as well
After earth strapping the conduits around my CU I went ot check the earth on a socket and the first one I checked had a very high impedance, so I took the socket off and looked inside and it was a proper single socket with the conduit connected properly.
Then I remembered this one was a spare from a double socket so I took the cover off to discover 3 conduits about an inch away from the metal box and not connected.
So that was two sockets not earthed, so I lifted up the floor boards and put earth straps on all three and connected them all together bringing up an earth lead into the socket.
Then I tested this socket and the spur socket and the resistance back to the earth in the CU was 0.3 ohms which is OK but I guess it should be less.
I need to check the rest but its not easy with the little one around but next weekend my mrs is away with him at a friends house for the weekend so hopefully I can get on and test things and try and improve it.
With pulling cables I guess you need someone else to help feed in the cables while someone pulls them to reduce friction.
Maybe I will get 1.0 mm2 cable for the lighting as it will be a bit smaller and easier to pull through but i will try the 1.5 mm2 cable first since i got it.
The other problem I got is the main fusebox for the flats now has a padlock on it and the council will only give the key to an electrician with a company id, which is all very well and good and I understand why they do it.
But I think it will tempt others to try things live as getting the key is unbelievably hard and has to be booked at least a week in advance.
I would have thought as the flat owner I would have the right to the key or even my own key, but its only really a problem if want to tidy up the tails.
