I'd be happy with the fully loaded MK CU that screwedfix are selling, providing the supplied MCBs were right for the particular installation.
JohnD said:I think you're looking at it the wrong way.
You've thumbed through the catalogue, and seen a bright shiny thing, and thought "that's nice, how can I use it?"
You should be looking at your installation first, and thinking "what do I need?" then looking to find a product that meets your requirements.
p.s. What has attracted you to the Hager, apart from the price?
You are right volex are regarded as s**t by most people but i have asked openion on wylex which is different.Hager 6+6 splitload with 10 mcb,s of ower choice for £ 80 seems good price but limited protection on RCD side 63amp only.Wylex on other hand similar spec with 80 amp rcd proctection again 10 mcb,s as a package ie, two 6 amp,four 32 amp,two 16amp,one 40 amp etc seems not bad either.I do not know which brand is most popular with sparks.plugwash said:seriously theese deals on fully loaded CUs seem to be about as good as you can get, they are usually much cheaper than buying the parts seperately. Just make sure its big enough, the breakers you need are included and its a good brand (hager are pretty good afaict, volex are regarded as s**t by most people here)
Pensdown said:It's a bit like like seeing a very cheap geny in a shed and thinking wow that's cheap how can I use it ?![]()
RF Lighting said:Personally I am not keen on wylex. I do not think the MCBs are very good quality, and the box seems flimsy.
I like hager, especially their new range.
RF Lighting said:Note the spirit level in the bottom of the CU![]()
ricicle said:The bubble ain't in the centre![]()
JohnD said:ricicle said:The bubble ain't in the centre![]()
A small shim under the end of the level would fix that![]()
If hager or wylex both are not your favourite then what would be your chioce.Nobody has shed any light on crabtree so for.securespark said:So the new one doesn't have that channel for the tails? And apart from the slight improvement of a metal rail, the rest of it looks flimsier than the last generation.
French carp!!
Thinks for a moment....is it French???
