hey plug, do you own the osg? because on the front page it reads on-site guide BS7671 :2001 (2004) wiring regulations including amendments....
I beleive that then makes it BS7671??
I also believe that the OSG guide was create for quick everyday reference using the full bs7671
If you then read about earthing a TT sytem the rods Ze will fluctuate according to the weather i.e if the ground is dry there will be minimal contact with earth whilst if wet there will be greater contact with earth.(it has been known for sparkys to 'wee' on the rods before testing to improve results). It then will tell you that if you have a earth loop imped which is too high (bad, to be expected with dry earth) that a 100ma is required...As the weather will be expected to dry at some point, even in england, you fit a 100ma as standard..now
The timer delay side is if you have a 30ma rcd on the board to protect the other circuits, which you would have (or is that something you don't do as well, tut tut). Surely you can work out why.
Now answer me this plug ....ARE YOU PART P REGISTISTERED??
If no I will not bother replying anymore, unless you wish to pay me training fees, if you don't answer I'll take it as a no.
If yes call the NIC they will confirm it for you...i'm not doing all your ground work!! and maybe get a refresher course
