A submersible well pump begins pumping when the mercury float switch in the water tank switches on a contactor. It stops when the water level in the tank raises the float and switches off the contactor/pump. For 15 years there was no contactor used and it worked well, indeed with no problems apart from pump replacements. On rewiring last year, the electrician said the law (?) required a contactor to be fitted where motors are switched.
After about a year, the contactor seems to go to sleep now and again. The float switch tries to switch on the pump but nothing happens. When you press the Off/Reset button, the contactor goes in with a bang and the pump fills the tank. It then works for a while but randomly goes to sleep again.
1- What is happening in the contactor to cause this indolence ?
2- Can it be made more reliable or taken out of circuit ?
3- If the top thing is a contactor, what does the bottom thing do ?
Pump - Ebara Idrogo M40/8, Q 20-80l/min, V1 230-240, I 4.3A, P2 0.6kw, HP 0.8, Hz 50, P1 1.0kw, Phase 1, min 2800, F 16, Vc 450, Ip 68.
Contactor - ABB - A9-30-10 4kW 230V - The bottom thing's dials are set to 4 A (2.8,3,3.8,4); Manual (Man/Aut).
//media.diynot.com/102000_101496_1125_45740586_thumb.jpg
