And the question is not about jets but prop engines, that need an air flow to get off the ground.
All forms of plane need airflow to get off the ground.
someone who will feel very silly said:Take a treadmill running at 5mph, if you stand on it you'll go flying of the end at 5mph, now for the clever bit.
And the question is not about jets but prop engines, that need an air flow to get off the ground. icon_rolleyes.gif
Now stand on that same treadmill with roller skates, and hold onto the bars.
Not going anywhere are you?
Now pull yourself forward with your arms, moving forward aren't you.
Your arms are a separate force from the wheels, just as the engines on a plane are. the wheels can do what they want.
Of course you're not going anywhere because you are exerting a opposite force to keep in the same position, exactly the same as an engine.
If you gradually increase the speed of the tread mill, eventually it would pull your arms off or your feet would leave the ground
to get it stationary you would need to exert and equal force in the
opposite direction to the planes travel.
The original question as everyone knows was flawed. Pointed out upteen
times by posters on here including physicists and highly academic professors.
So until some professor rewrites the original question then this argument will continue going down separate paths.
Hands up, all those that think free wheeling wheels can brake 120,000lb of thrust.
