conveyor belt and plane answered at last ??
If the planes forward speed is matched exactly by the conveyor belt going the other way then the plane will not move relative to the Earth. If you run too fast on your running machine you move forward, too slow you move backwards.
Now imagine you are on that treadmill on a unicycle and have a rocket pack on your back. Now what happens? NEWTON'S THRID LAW.
Are we dealing purely with forward/backward momentum here? If you are going forwards with the unicycle, and the rocket pack is moving you forwards aswell then unless the treadmill counters your speed exactly you will go forward.
It has nothing to to do with Newtons law or Grasshoppers for that matter.
the original question stated that the conveyor speed matched the plane speed
It's a trick Joe under stand the above quote taken from the original post.
For what it's worth the conveyor could be stopped, if the plane matches it's speed it still isn't taking off.
Million lb thrust and rockets to mars make no different.
Conveyor speed matches plane speed - not wheel speed. The wheels simply spin at twice the speed.
Interesting how very few 'experts' on this thread are measuring speed in knots rather then mph :rolleyes:
It's a nonsense question. As soon as the aircraft moves forward the wheels will be moving faster than the conveyor and the experiments rules are broken.
The question doesn't mention the wheels.
If it were a car then the wheels would be crucial. But for a plane they don't matter they simply spin freely at twice the speed.
It's all down to NEWTON'S THIRD LAW.
i'm still not convinced either way...
the story is this... you have a plane on a runway. However, the runway is a conveyor belt which will run at the same speed at the wheels of the plane. Will the plane actually take off?
Yep, no mention of wheels there :rolleyes:
This is the original question....
An aircraft is standing on a very long runway that can move (a conveyor belt). The aircraft moves in one direction, while the conveyor belt moves in the opposite direction. This conveyor belt has a control system that tracks the aircraft's wheels speed and tunes the speed of the conveyor belt to be exactly the same as the wheels, but in the opposite direction. There is no wind. The pilot begins to add thrust to the engines...
Will the plane ever take off?
When it says wheel speed it means the speed of the axle - not the rotation velocity. Otherwise the question is invalid as any movement is impossible.
Well done Joe I think you just hit jackpot :LOL:
The question is not invalid, it asks will the plane take off given the above conditions.
"No the plane will not take off"
Not at all. It means the question is invalid as the only time the wheels are in sync is when they don't move. That wasn't the sprit of the question, just read wrongly.
No Joe, that is the question, you can't re-word it to suit or make your own rules.
The conveyor is travelling at 85mph and the wheels of the plane are doing exactly the same as the planes forward trust holds it in place.
If the wheels go slower the plane will go backwards, if the plane goes forward the wheels must be going faster than to belt to make ground.
Same as the tread mill, you can run on the spot at 5mph whereas if you run at 6mph and the belt travel is still 5mph you'll run off the end.
You aint getting it. If the power is applied to the belt through the wheels then NEWTON'S THIRD LAW APPLIES at the WHEELS and what you say is true. However if the wheels are allowed to spin freely and the engines deliver thrust - THEN NEWTON'S THIRD LAW applies at the ENGINES. Fook all to do with the wheels. NEWTON'S THIRD LAW is LAW. :rolleyes:
I'm not getting it :LOL:
We all know what you are saying Joe, but it is not within the context of the question. The rules are laid down right or wrong, you must answer the question accordingly, not re-write it and quote space rockets, jumbo jets or even Newtons law.
Did you know that if you turn the plane round so it is facing the direction of the conveyor belt travel, at 85knots the plane will leave the ground and the wheels are not even turning and the engine is turned off. :mrgreen:
Ok, if you choose to live in a world of nonsense because you've lost the argument that's your choice. :rolleyes:
