cooker cable size
20 Mar 2010
Lancashire
just a quick 1
got a job 2 connect a oven (no hobs)
power 3200-3500
current 13-15 amp
in the maual it says it has to be on a 30-32 amp supply and 4mm heat resistance cable must be used to connect the cooker to the outlet
could you use 2.5mm heat resistance cable to connect from the cooker to the outlet with it being cappable of handling 15 amps or is it 4mm for a reason?
forgot to mension the circuit for the oven in the property at the moment is a 20amp supply and 4mm cable
got loads of 2.5mm but no 4mm that was why but i agree i will have to get some 4mm then :D :cool:
I suppose you can't have 2.5 mm flex protected by a 32 amp supply.
Then again, I would have thought 2.5 mm cable protected by 20 amp supply would be fine for a 3500 W oven...
thats what i was thinking, to be honest i went to two electrical wholesales today for 4mm flex and both of them said they would have to order me it in
Is the oven a foreign (European) product by any chance?
I'm not saying you should ignore the instructions btw.
efl....... no but that was what i thought
normaly when in fitting cookers ect it just gives you the specification
not what cable, supply to use ect
Methinks that the power and current variations relate to the possible supply voltage variations (220-240v, perhaps).
My oven is fitted with 4mm heat resistant flex, and I remember having trouble getting hold of it. I ended up ordering from TLC in the end as none of my local wholesalers stocked it.
Having said that however my oven is a double oven and is rated at around 6kW (I don't remember the exact figure).
I don't see any reason why the oven you're looking at couldn't be fitted with 2.5mm flex on a 20A, or even 16A, breaker. But on the other hand I'd always try to observe the manufacturers instructions :)
