If it helps the cooker MCB says B40, does this mean 40Amp? And the lighting is B6
Do you mean the 'previous fusebox' (tucked away in some box in the garage, not in service)? If so, I'll be intrigued to know what you have in mind!Do you still have the old fusebox without RCD protection?
Ah - my apologies. I hadn't noticed that you said that when you re-wired your house that didn't incude installing the CU or commissioning the system. I was thinking that you had done everything, and therefore were comfortable (and 'competent') working in a CU, and your talk about possibly moving MCBs rather reinforced that impression that I'd gained.Thanks for all your thinking - It is hugely appreciated! With regards to disconnecting the lighting circuit this would make perfect sense. However i have never messed around with the consumer unit, is this something easy to do and what precautions so i dont electrocute myself!
What kind of camera do you have that doesn't store images as either JPG, GIF, PNG or BMP files?
Try resizing them first too!
There isn't an under cabinet light, light switch or something running too close to the cooker? No cable run behind the cooker which is squished, and failing when the cooker is hot?
Does the MCB go with a pop when you try to reset it?
If it was reseting onto a fault, it would make a pretty lound bang/pop noise.
It certainly sounds like the MCB is shot - I expect it feels 'loose' when you try to turn it on, there being no resistance or click?
Change the MCB for new, and perhaps the cooker one too (it could be getting too hot).
I can't remember now, but did you say it was a wylex? They had some B6 and B16's recalled two years ago as they were failing quite spectacularly. Perhaps you should see if you can get the batch number off the side of the MCB (it needs removing to see it) and post it here.
Indeed, although even then, to be totally safe, you should really do a test to make sure that main switch has really done its job.OK - so common sense prevailed - If the main switch is off then no power flows past there in to the CU.
Thermal 'triggering', almost certainly, but I frankly wouldn't expect an MCB to behave like that - unless, perhaps, the one next to it was red hot or on fire - I therefore suspect that you have a 'shot' MCB.I have run the suggested test and disconnected the lighting circuit completely and left the MCB on. At first it wouldnt reset from the previous test a min or before - then after a couple of minutes i tried again and it reset OK. I then started up the oven and grill and it tripped after about 30seconds.
So i am presuming this would suggest that it is thermal interference then?
