It does - but, as I said, I was using the word in its everyday sense and felt sure (and still do) that the OP would have taken it to have that meaning. Apart from anything else, he clearly is not 'competent' in the 'particular connotation' sense.John, I'm not playing word games. In electrical installation the term'competent' has it's particular connotation.
Yes - well, actually, if he felt 'competent' (as above, everyday sense).The OP asjked if it was easy and your reply was yes (basically if he felt capable).
Hmmm - explaining to him any of the processes required was the very thing I was trying to avoid doing - and I imagine that, if I had done, I would have attracted even more flak. AS I said, I assumed (as we now know,incorrectly) that, in view of what he had preciously said, that what I said would 'put him off'.Not mentioning the process for proving dead (before he changed the MCB) was wrong
No argument with that.Proving Dead is not an option for when you are not quite sure if the supply has been cut, it is something you should do as a matter of routine.
I don't really understand why, from time to time, you seem to single me out for for these 'criticisms' - and particularly why you've done so in relation to this thread, in which I genuinely thought that I was discouraging the OP from doing things which he might not be adequately knowledgeable/'competent' (everyday sense) to do. A pretty high proportion of threads in this forum involve activities which should involve testing for dead (e.g. lighting/lighting switch wiring, circuit extensions etc.), yet you will rarely see (there are obviously exceptions) any mention of testing for dead, let alone explanation of the process for doing it. Indeed, when anything about safety is said at all, more often than not it is simply along the lines of "make sure that the power is switched off" - which an OP is likely to take to mean that 'switching off' is enough. I therefore don't really understand why I seemingly get singled out, even when I'm encouraging an OP to utilise the services of an electrician.
Kind Regards, John
