moved into a council house where the 32amp cooker switch is on the wall to one side of cooker opening which leads to a 3 pin socket behind where the cooker is going. My question is would it be ok to wire a 13amp plug to the cable thats comes from the cooker to the 3 pin socket. As the socket is on the 32amp circuit. Cooker specs :-
Installation
Electrical Connection 9.8 KW
Fuse Rating 32 amps
Minimum Distance To Cooker Hood 65 cm
Power Requirements Needs Hard Wiring By Electrically Trained Engineer
Requires Electrically Trained Engineer Yes To Hardwire (Cable Not Included)
Installation
Fuse Rating 32 amps
